andare Well-known member Jun 2, 2023 #1 The build doc shows this But the board is blank. Is this the correct orientation? Thanks!
Z zgrav Well-known member Jun 2, 2023 #2 just for neatness I would install it with the numbers oriented with the footswitch at the "bottom". either orientation will work for the switch.
andare Well-known member Jun 2, 2023 #3 zgrav said: just for neatness I would install it with the numbers oriented with the footswitch at the "bottom" Click to expand... I don't understand what you mean.
Betty Wont Well-known member Jun 2, 2023 #4 andare said: I don't understand what you mean. Click to expand... The switch works either way you install it.
Z zgrav Well-known member Jun 2, 2023 #5 I am just referring to the 1 and 2 and the "on" label. put it whichever way you think looks best when you are looking at the board.
andare Well-known member Jun 2, 2023 #6 Betty Wont said: The switch works either way you install it. Click to expand... I got that part, I was confused as to how to orient the switch but @zgrav clarified it now. Thanks everyone!
