Hi All,
I decided to troubleshoot an old build that somehow could not figure put a few years ago. Queen of Bone 2 by rullywow.
The #2 side works without issue. In side #1 (right side) When it is engaged I can only get volume if gain is above 0. Also, the volume pot increases volume up to about 1 oclock and then comes down. Max volume is slightly bellow unity. Plenty of volume on side #2.
Here I what I did:
- Checked voltage at the opamp, comparing both sides, they seem quite similar.
-Diodes switches are both off (clean boost mode)
- Traced the audio circuit with an osciloscope. It seems the gain & tone circuits function as intended. (1Khz signal) If volume is at 0, the audio signal is strong at the volume pot input pin.
-I removed both output caps and resistor. I could then control the output signal with the volume pot. I then thought, it must be a bad cap.
-Installed new output Caps (C9 & C10) and resistor.
-Disconected switching daughterboard to mesure only #1 circuit. Same behavious, volume goes down after about 1oclock.
-Replaced opamp
-Replaced charge pump
-Replaced volume pot.
This is puzzling...
Thanks for any insight!
Here I what I did:
-Replaced opamp
This is puzzling...
