Mach 1
Wow cool design !
Tayda UV print ? If yes did you vectorize it ?
Thanks. Yes it was a Tayda UV print. I think this was the first design I did before learning how to use Illustrator. I used autotracer to vectorize it. Most of the ones I designed after used Illustrator (it does a better job).
Thanks for your answer, I'm gonna check that, I'm not very familiar with Illustrator it drives me crazy sometimes ! 😬
If you have a copy of it, it is probably worth learning how to use. Just load up the image in AI and then go to window --> image trace to create a vector image. You can increase the # of corners, paths etc if the detail is too low.
Ok thanks for the tips ! I'll try these for my next designs (y)
