Selected between pin 1 and pin 3 of the 4013How does the toggle work?
Yep. Well, I used pin 13. But so long as the connection to pin 1 is severed and you use either of those pins, you get the One octave down.Selected between pin 1 and pin 3 of the 4013
Very cool that you modded this. I built the Fuzzdog version with a switch for 1/2 octave and I much prefer the 1 octave. @KR Sound you could reference the Fuzzdog build docs, but would also be cool if dgwvi shared the direct ppedalpcb board mods
Can you please elaborate on how you maxed out the MicroAmp at the output? Mine sounds like the stock demos, but I'd still like the output to be louder.I maxed out the MicroAmp at the output.
I built the FuzzDog MicroAmp stock, except instead of the Volume pot, I jumpered lugs 1&3
Super simple. Hardest bit is tacking the flying lead to the IC leg and not snapping either one
Or in my case with the sockets, not oversaturating the leg with solder
Lift the leg of R20 (1M) attached to pin 1 of the 4013 (the bottom hole) and solder that lifted lead to a wire.
This wire gets soldered to the middle lug on an SPDT ON/ON
Solder two more wire to the outside lugs of the switch. One will go to the now empty hole at R20 (-2), the other will go to either pin 13 or 3 of the 4013 (-1)
Pic indicates which leg to lift
Pin 13 should still be in the socketHey there!
I've done the build with this mod but it not working correctly when the switch is to the -2 octave. Maybe I understood the mod incorrectly.
Could you look at what I've done and tell me if everything is supposed to be ok?
Thanks in advance man!
Rubber stamps- either Pegz brand (typewriter) or a custom set (peignot)nice! how you doing them cool stamps for labeling?
