Yes, I over-tightened it like a dummy. Thank you for the video. I could cut through the knob which would take a while, but I am hoping I can just drill through the screw enough to get an allen key in there and loosen it enough to pull the knob off. I already ordered some replacement knobs so I am ready to sacrifice it! I hope I can save the pot, but if not, then I can get another.did you over-tighten the screws on the knobs and strip the slot? there are also some special drills bits you can get to remove screws, but sacrificing the knob is likely to be the cheapest and quickest solution. Some interesting ideas about removing stripped screws in this video.
Hey thanks! That looks to be my issue. It might take some time, but I will swap with the correct ones. Hopefully that fixes it!Looking at the build docs, the pic on the web page for the PCB and the pic of your build, I see a few discrepancies. Check and see if you can see the values printed on the PCB with out removing the resistors, if not you may have to do continuity checks to verify them. The circled resistors are the ones in question and the color code value is next to them. Mr. PedalPCB usually says to go with what is printed on the PCB as these are the most up to date.
Circle color What you have installed What it is According to web page/Build DOC
Red 10K R11 - 22K
blue/green 22K R8 - 100R
pink 47K R4 - 10K
Orange 680R R102 - 47K
White 100R R10 - 680R
YOU NEED TO VERIFY THE VALUES TO YOUR BOARD!
GO WITH THE BOARD!So, I managed to get the incorrect resistors out.. or at least the ones you highlighted.
As I was taking the resistors out, I noticed that they are marked with the incorrect value on the board, which is most likely how I mixed up the values so badly. I have no idea if there are others that are incorrect.
It is definitely my fault for not checking and verifying the build doc with what was on the PCB, but I do think @PedalPCB might want to consider either including a warning that the values aren't the same or maybe not have the incorrect values on the board lol
