tone.electronix
Hello people!
Hope everyone's doing OK
So I recently built a Module8, the old version with a 100KB pot for selecting the program (not the rotary switch like the new version).
One thing I noticed is that using this selection method (pot) sometimes it's pretty hard to find the right sweep for a certain program, like you really need to nail the right spot to get the effect you want, it's a very narrow tolerance on the rotation of the pot. If you move a fraction of a milimeter to the right/left, you select either the previous or the next effect.
This just occurs to a couple of effects selection, not all.
I guess this could be a problem with the pot itself since I already checked all the resistor values and I guess they are soldered in the correct position. So I'll try a different pot as soon I can get one.
Now, for the main question: there are some effects that I will not use, or doesn't fit my taste. So I was wondering, can I order a Custom eeprom and swap it directly, with no other changes to the components?
Thank you so much!
TX
Thank you so much!
TX
