G.G.
Hi guys,
I just put together my Mojito build and I'm not getting any sound at all from the output. Oddly, when I use an audio probe on Lug 2 of the Output pot it sounds like the circuit is working fine, all the controls work and it sounds great. When I test with my DMM I'm getting continuity from Output Lug 2 to the tip of my test rig output jack. But I also get continuity to the jack ground and also to the PCB pad right below the LED anode in this pic which I believe is also ground. I noticed the PCB trace from Output Lug 2 to the Output pad has a small spot on that looks like maybe the ground pour is touching the trace, is that possibly the problem? I can just run a wire from Output Lug 2 to my switch easy enough, but it's such a weird problem I thought I would run it by you. Any thoughts?
