Moonshot Trem (no signal when engaged)
I thought this was a straightforward build, but here I am. Bypass works fine and all the LEDs work as they should (pulsing). I don't know where to start with troubleshooting.
It depends on how your meter displays values in a particular range.
47.0 could mean 47K since you're in the 200K range.
Measure the 10K resistor two resistors above that one (below the 330pF capacitor) just for comparison.
I'm stumped... Your 9V supply is dropping across R101 so there must be a short of some sort.
With the IC removed the only components on that line are R101, R102, and C101.
Unless C101 is defective there must be a solder bridge or other short underneath one of those components, or the IC socket itself.
I'll check/replace c101...these sockets are about impossible to remove, huh?
It can be a little tricky, it's usually easier to just destroy the socket rather than try to salvage it.
Before you start pulling a bunch of components check for continuity between Pin 3 or 5 (they're connected together) and each other pin of the socket.
I pulled both c101 and c5 (the strip had turned red indicating too much heat). There's only continuity on pins 3 and 5 on the tl072 socket. I've been staring at it all day and can't find any grounding issues...I've got another board, but I'm afraid to try it.
