What I'm saying is don't turn the DRIVE up past 8 because no capacitor will be big enough for C5. If you need more gain, put a booster in front.
OK, the reason I'm ? at your last question is an octave-up circuit inverts and doesn't invert. It does both at once, that's how it makes the octave-up. What that means for you is that you never have to worry about inversion with an octave-up circuit.
To get a little more technical, the concept of relative phase only has meaning when the two waveforms you're comparing are the same frequency. Change the freq with an octave-up, octave-down or a pitch bender and phase goes out the window.
Give the buff-n-blend a try, it may get you where you wanna go with the least amount of trouble. If you don't already own a Parenthesis, you might consider building one because it sounds like it might be just what you're looking for.
