Muffin Factory Input Resistors and other build information
halffast
I'm new around here but I have built a few pedals.
I plan to buy the Muffin Factory PCB and was studying all the options it has. Very very interesting!
Question: On the Muffin Factory schematic R3 input resistor is 110k with R2 47k in parallel controlled by a DIP switch. Why is R3 110K?
https://docs.pedalpcb.com/project/PedalPCB-MuffinFactory.pdf
I understand what the 47k in parallel is giving for input resistance.
But that 110K alone is bigger than any I've seen.
Enlighten me please. Thank you.
Because that is what was in the original.
This and another pair of values (discussed in another thread) have always bugged me...
I suspect that the intention was for those values to be swapped, 47K in the fixed position and 110K switched.
This would allow the dipswitch to select between 47K and 33K input resistance, instead of the current 110K / 33K.
Thank you Robert.
Yes, swapping them around makes more sense to me also.
Every schematic I've seen so far of any early Muff's have 30k-ish input resistor so thats why i was wondering.
Sifting through Kit Rae's schematics, and maybe a few others I've found online, the range of Muff input resistors found from smallest to largest:
27k, 33k, 36k, 39k, 43k, 47k.
I think that's got them all.
Then there's outliers such as the:
  • 2k7 Earthbound SuperCollider
  • 3k3 DiceWorks Muff Diver,
  • 8k2 AceTone Fuzz Master FM-3,
  • 10k Ibanez OD-850 (& Maxon D&S OD-801),
  • 12k Blackout Effectors Musket (LPB Boost before Muff, NO input-resistor),
  • 15k Civil War w/ Power Booster (PB comes first and has NO input-resistor),
  • 39k & 390k (switchable) BAT Pharaoh (if the 390k were in parallel with the 39k it would give 35k45)
Last one is according to Kit Rae's site, but 47k and 470k seems more likely given the rest of the circuit is almost entirely "47x" numbers.
PS: If for some reason you want to target a specific Muff-input resistance, a different value than parallel 110k & 47k — paralleling Tayda-available resistor-values with the biggest Muff-input value, 47k +...
62k = 26k7
68k = 27k7
110k = 32k9 (STOCK Muffin Factory)
113k = 33k19
118k = 33k6
120k = 33k7
150k = 35k78
160k = 36k3
220k = 38k7
240k = 39k3
470k = 42k7
510k = 43k
560k = 43k3
Not sure why anyone would want/need something close such as 47k and 43k; I'd want a bigger spread such as the 33k and 47k, though the most common Muff input resistor values, hazarding a guess, are 33k & 39k.
Using Rob Robinette's SPDT ON-OFF-ON...
MUFF INPUT-RESISTOR SPDT on-off-on 3 PARALLEL resistors Cold_Clipper_3-Way_Switch.jpg
BUT WAIT!
... I don't like that the order of magnitude is all mixed up. I want levels to be logical: SMALL MEDIUM LARGE — in that order!​
That gives me the full spectrum of Muff input resistance, from lowest to highest and the 36k in the middle straddles the line between the most common values 33k and 39k — perfect for me!
You could swap the 47k and 27k if that order makes more sense to you;
you could orient the switch so it operates left-to-right;
you could swap out the TYPE 2 for a TYPE 1 on-on-on, easily...
Wow Feral.....thanks for your time with the detailed reply. Very helpful!
Because the Muffin Factory already has input resistor R2 on a DIP switch I will use it and stay with the spec'd values resulting in 47k or 33k.
Makes the most sense I'm thinking.
Glad I saw this. The muffin factory is my next PCB I’m populating, and I am just getting started on the big muff rabbit hole.
Besides swapping r2 and r3, are there any other un-muffy things going on in the muffin factory that could be better muffified?
@jcpst, I started this thread......
I have not studied the schematic any further but I will and will post back if I have any more questions.
I have looked into the parts needed and I ordered them morning. I was concerned about which header pins to use to ensure the DIP switches sit nicely, flush or a bit above the face plate. So I ordered two different header pins from Tayda, A-7566 and A-4662.
You can enter these numbers in the search box at Tayda to find them. One has a over-all height of 12mm and the other 16mm. They will have to be cut to the 10 pin length.
I discovered short lever toggle switches at Tayda and ordered them to see if I will like the look. Tayda A-2559 and A-3675
And I really liked this DIP-5 switch, it has tall toggle levers. Mouser # 653-A6E5104N
Thats it for now.
None of the Classic values are going to make a difference, i.e. 27k-39k.
You have to remember that a lot of those component variations in those old muffs were inventory driven, i.e. If they changed the tone stack resistor from 33k to 39k they’d probably change the input resistor to use them up.
At least that’s how it always seemed to me.
I know EHX always bought on economies of scale and used whatever was at hand, but even so — was the entire Muff input-section modified in other ways to compensate for differences in the specific input-resistor value? Probably not. If not weren't the differences audible?
While 33k to 39k isn't much of a difference, a 27k vs 47k is a pretty big swing and would also affect the input-impedance. Lower resistance on the input-resistor and you've got a hotter signal hitting the rest of the circuit. If this difference is audible or not I don't know, I haven't toyed physically with the circuit much even though I've got PCBs fully socketed for it for experimentation, I've mainly toyed with theories.
For example, some early Ram's Heads had a 10µ input and output cap, so you'd think they'd be great on bass, but the internal workings of the clipping sections have 1µ clipping caps — compare that with the Bass-players' favoured Russky Muffs with 100n input/output caps and 47n clipping caps...
Input resistors — audible differences? Audible in a band mix?
I should spend less time yammering about this stuff and more time physically trying things...
Feral has some great observations!
I was quite surprised to see that 110k input resistor. I think I will use a 39k with a 100k in parallel for a choice of 39k or 28k.
I've only recently played around modifying late version Muff's, the most inexpensive ones.
As I am studying the Muffin Factory options on the schematic to the older original Muff versions, I feel like my head is gonna explode!
My hat is off to the designer. Well done!!
It is written that one area of the Muff circuit that has a large impact of the sound is the cap in series with the clipping diodes.
The Muffin Factory schematic shows both clipping stages with a 47n cap with a switchable 100n in parallel.
So we can choose between 47nf or 147nF as it stands. Some Muff's have 1uF and even larger.
So I was thinking of trying .1uf and .68 switched in parallel. I liked both at .47uF in my experimental Muff.
But one issue is that customizing a build will negate the existing setting spreadsheets........
Below, I show a screenshot of the stock Muffin Factory tone circuit. In red are the resistive and capacitive values with the DIP switches closed.
Typical BMP tone circuit high and low pass filter values are shown in this table:
https://vero-p2p.blogspot.com/2021/01/big-muff-electro-harmonix-component.html
Typically values shown are 400 to 800Hz for the low filter and 1k to 1.8kHz for the high.
The Muffin Factory tone circuit filter values with a 130K resistor are wacked! Not even close to the typical BMP tone filters.
What am I doing wrong?
I'm inputting the capacitor and resistor values into this:
https://www.digikey.com/en/resource...sion-calculator-low-pass-and-high-pass-filter
BTW..I run Mac computers, is there a Duncan tone stack calculator for Mac?
No DL-able DTS for Mac, but...
That's what I use, I'm on a Mac.
Thanks to @FeralFeline I can run some plots of the stock Muffin Factory.
Here is the plot using the fixed (not switched) R and C values:
Not too good. Am I doing this right? Why would the 130K resistors be specified as nonswitched?
Formatting's a little wonky, but maybe this helps (C9 R5, R8 & C8 as per Kit Rae's schematics):​
The above chart's HPF/LPF corner freq being derived from the AMZ calc, not from TSC.
PUNKN Pi Op-Amp FROM DOWN UNDER, (refdes on Paul’s BMPOA-offering schematic)
Also check out Aion's Muff build-docs, Kevin's got a lot of good info on kajiggering the tone stack to exaggerate/attenuate the mid-scoop as well as making it FLAT.
BuddytheReow, helpful as always, with his fine tutorial right here on the forum.
Here is the tone stack with both resistor DIP's closed for 39k on both.
So.....I figure that since I want to build a Big Muff based Muffin Factory, one that will give some classic Muff tones then I will need to re-design some of the switched values. I will post my resulting changes. In time.
But the #1 reason I decided to build this Muffin Factory is for the build itself along with some customizing. Thats the fun part.
Is there a similar complex pedal out there?
So again....I appreciate those who did all the hard work involved to bring this to market for us all.
Thank you @Feral Feline for that Muffin tone stack data table!
I've seen many posts by you about the MF build. You've been interested for quite some time looks like.
Now is the time to buy the PCB and faceplate since you can get 15% off.
I bought mine about 5 days ago. I don't know if that offer was active but I missed it.
Thanks Halffast.
I've got two Muffin Factory PCBs already, awaiting components & solder.
Back to the Rabbit Warren...
It may be hard to see a particular tree in the forest; but if our beloved Muffin Factory is based on the W&C multi-Muff and you want to stick to EHX specs and not some boutique crazy-variant values...
I'll say there are a couple more places that wouldn't hurt to swap the stationary resistor for the switched value (parentheses below with outliers boutique-ish or otherwise):
PPCB MFKIT RAELOWEST EHXHIGHEST EHX
R10 Limit-resistor before 1st clip 33kR197k5 ♈︎ (Super-Collider 5k1)12k ∆ (reputedly there is a rare Russky☭ with a 39k)
+ R9 Muffin Factory Parallel to R10 11k
R18 Limit-resistor before 2nd clip 18kR127k5 ♈︎ (Super-Collider 5k1)12k ∆ (Frank Zappa's BMP 47k!)
+ R17 Muffin Factory Parallel to R18 15k
R12 Feedback resistor Clip1 1M3R17390k ∆ (220k Jordan)470k (Super-Collider 1M)
+ R13 MF Parallel to R12 560k
R20 Feedback resistor Clip2 910kR15390k ∆ (270k Jordan)470k (Super-Collider 1M)
+ R21 MF Parallel to R20 680k
R16 Emitter Resistor Clip1 1k2R21100r (GND for Jen & Creamy Dreamer)430Ω early ☭
+ R14 MF Parallel to R16 120r
R24 Emitter Resistor Clip2 1k2R1082r PNPR10 390Ω V7☭
+ R22 MF Parallel to R24 120r
I skipped the input resistor in the above table 'cause it's already been discussed as has the 130k in the tone-stack.
Compare the following combined parallel resistors' values with the related EHX in the table:
PPCB Muffin Factory refdes:
R9 || R10 = 8k ... a common limiter-resistor EHX value
R17 || R18 = 8k ... again, a common limiter-resistor value
R12 || R13 = 391k ... Feedback resistor 1st clipping section
R20 || R21 = 389k ... Feedback resistor 2nd clipping section
R14 || R16 = 109Ω ... Emitter-resistor 1st clipping section
R22 || R24 = 109Ω ... Emitter-resistor 2nd clipping section
In addition to the input-resistor swap and the tone-stack resistor swap, I might swap the following to get more EHX-like values than the "stock" Muffin Factory values in parentheses below:
SWAP Rs gets VALUES more like EHX
R9 & R10 to get 8k & 11k (instead of 8k & 33k)
R17 & R18 to get 8k & 15k (instead of 8k & 18k) [Could even go more EHX-like with 8k & 12k via 12k || 24k — same for R9&R10 above as 11k is weirdly un-EHX-like]
R12 & R13 to get 391k & 560k (instead of 560k & 1M3) [390k being a stock EHX value, and 470k instead of 560k would be even more in keeping with EHX, so 2M4 || 470k = 393k]
R20 & R21 to get 389k & 680k (instead of 389k & 910k)
Nor sure if I'd swap R14 & R16 as well as R22 & R24. That 1k2 is big bootiki territory, but an EHX-430Ω upper value with MF's 120Ω might be too subtle?
If swapped the modifying Emitter-resistor for the first clipping section, 1k2, would need to be 160Ω || 430Ω-EHX to get 116Ω6. Close enough to Muffin Factory's 120Ω?
or 180Ω || 430Ω to get 127Ω.
160Ω || 390Ω gets 113Ω
180Ω || 390Ω gets 123Ω
Early EHX Muffs had that 120Ω value for clipping section emitter-resistors. Then came bigger and smaller — 150Ω, 100Ω. The Russian-built Muffs arrived with 390Ω...
Anyway, for the Muffin Factory to stay within EHX norms, that's dagnabbed near every parallel pair that needs swapping (and some with an alternate value to the modifier-resistor needed).
I'm guessing W&C were going for both non-subtle Boutique swings and EHX-ish, as opposed to confining the circuit to EHX&EHX subtleties.
So, depending on if you want a wide ranging custom boutique-values Muff or if you want a more subtle all-the-EHX-Muff flavours build... you can play with some resistors and tailor the circuit to suit.
Muffin Factory interstage coupling caps......
Options are 100n fixed and 22n switchable so a choice of 100n or 122n.
Seems like a smallish differential?
I'm thinking keeping the 100n fixed and using something like 680n switchable?
Thoughts? Since many of you have much more experience with Big Muffs and clones.
