I've been porting the MultiDelay example from the Daisy Examples. It's kind of turned into a mix of the Petal and Patch examples. Not 100% happy with it, yet. I will probably tweak the approach, a bit. I can't help myself. FYI, I'm only developing on the Linux platform, should be easy to compile on Windows and Mac but I'm not going to provide any support for those.
Here's a brief description of what I've got so far.
# Description
Three delay bundled in one. Set their delay times independently. Feedback is controlled globally.
The three delays are mixed with the dry signal.
Set the dry/wet amount of this final mix with the dry/mix ctrl.
# Control
| Control | Description | Comment |
| Ctrls 1 - 2 - 3| Delay Time | Time for delays 1 through 3 |
| Ctrl 4 | Feedback | Feedback for delays 1 through 3 |
| Ctrl 5 | Dry/Wet Mix | Set the dry/wet amount for the outputs |
| Foot Switch 1 | Passthru | Illuminated when set to passthru |
As you can see, I still have one more Ctrl (Pot) available), all 4 switches and Foot Switch 2.
After I tweak it a bit more and clean up the code, I'll post it the github repository that started for Terrarium examples. I can also make the binaries available. If anybody wants to help out (either with code or suggestions, feel free to let me know). How many have a working Terrarium and have figured out how to program it?
# Description
# Control
