Hi all. I’m sure this is a common scenario but I am building the Muroidea and I am not getting anything when the pedal is engaged. I have triple checked all of my components for accuracy. The LED works and I get signal to my amp when true bypass is doing its thing when the pedal is switched off. The only parts I had to swap out were the op amp and the JFET transistor, but I checked the forums and read that both were acceptable swap out options. I had to use a TL071 op amp and a 2N5457 JFET since Tayda did not have the required parts in stock. I will start by posting some pics of the board itself. More pics will be available upon request.
