Hi!
Following this thread: https://forum.pedalpcb.com/threads/muzzle-not-gating.10381/#post-102770
Testing out my muzzle, it gives me a very high pitched squeal when using overdrive channel. It occurs even if the pedal is turned off. With clean channel it seems to work fine.
Here's an audio clip demonstrating the problem: https://www.dropbox.com/s/ep5wh1c6ueul2qg/muzzle squeal.mp3?dl=0
At the end of the clip I'm turning it on and off and rolling the pot from min to max. When engaging the internal switch the squeal is still there, but just lower volume. If I take out cables from key in & out and go from my guitar to amp input and leaving the muzzle in loop, there is no squealing. My fx loop is supposed to be instrument level and I've tested the original zuul with an amp that had line level loop, and it worked fine. Any suggestions?
