Rando_calrissian
I just finished the build but it won’t power on where should I start?
-4.2What is voltage at pin 5 of LT1054?
Checked it over again and the key wiring is correctDouble-check the key jack wiring.
Did you use TRS Jacks for key chain?, they look like mono jacksChecked it over again and the key wiring is correct
Yes I used the ones linked on the bom pageDid you use TRS Jacks for key chain?, they look like mono jacks
YesDo you get Continuity if you put DMM test leads on solder switched tip & tip terminals on Sidechain jack?
The voltages are all over the place, Clean the board & check for Dry joints & Bridging, ie solder jumping onto another pad.Ic3
1-8
-.02
-.02
.001
-2.637
.002
-.013
-.013
8.66
Ic1
1-8
1.989
4.646
.005
-3.096
-6.61
2.558
1.392
8.68
ic2
1-10
-.262
-1.385
-.836
-.332
-.285
-.404
-1.619
0
0
-2.615
11-20
8.67
-.287
-.286
-1.648
-1.62
0
-.295
-.411
-.259
.003
It is getting .709 on the collector and .156 on the emitterCleaning didn’t help anything but one major problem I see is that q2 is not receiving 9v from the rail as it is supposed to
What voltage are you getting at Pin 5 on the LT1054 ?It is getting .709 on the collector and .156 on the emitter
.156vdcWhat voltage are you getting at Pin 5 on the LT1054 ?
