Rando_calrissian
I just finished the build but it won’t power on where should I start?
8.71vdcPin 5 goes directly to the Collector of Q2.
What voltage is at Pin 8 of LT1054
Replaced the lt1054 and now I’m getting -6.68vIt's very likely.
Just for the heck of it, pull out the THAT4301 and then measure the voltage on pin 5 of the LT1054 again.
With the chip pulled it’s -8.35Remove the THAT4301 & see what voltage, you should be getting -9v!
United statesWhat country are you in?
Saw some post about alibaba clones that work but you have to order a minimum of 5 at 17 dollars eachFrom all my searching it doesn't look like I can get any at this time
That’s 30 dollars is without shippingI have used this site & Hector has always sent genuine parts.
Contact him to send a picture to be sure!
THAT4301P20-I / THAT 4301 That Corp.,DIP20.
THAT4301P, THAT Analog Engine® IC Dynamics Processor. ThatCorp, DIP20www.retroamplis.com
