jimilee
See, I felt the same way.I'll go ahead and be the voice of dissent on this one, I really dig the AI generated one, I think it's a killer look.
Right? I was so proud of that oneThe AI “artwork” is missing the clever visual pun of the original. So, purely on those grounds it is inferior.
I doubt it, that's basically garbage. There are some AI engines that are capable of generating actual working code from a prompt, but they aren't free. Most will basically just give a well formatted nothing.Does it work?
Yup they can be good for generating stuff that isn't super complex but would be time consuming to write by hand. They can also help with formatting something that's going to be written and finalized by a human. AI generated code can be useful when it's being reviewed by someone that knows what they're doing, but I don't trust it to generate full working code the first time.Some of our coders in the company use ai supported tools but not just to generate code but to elp write the code.
PLEASE post that complete code here! I'd like to try it.This got me thinking, can chatgpt produce code for a FV-1?
So I asked it.
Here is the response.
Yep. I use AI to help write code at work. I know exactly what I want it to generate, it just saves time typing it out. Over time, you learn the situations where it will most likely do that. I read every line it spits out.AI generated code can be useful when it's being reviewed by someone that knows what they're doing, but I don't trust it to generate full working code the first time.
Deleted the original code so had it ask again. Here you go!PLEASE post that complete code here! I'd like to try it.
I was hoping to acquire the ASM code. It looks like that first section IS the ASM code, but it needed to be wrapped on CodeQuotes before posting. A lot wa lost in the HTML translation. Thanks anyway man.Deleted the original code so had it ask again. Here you go!
Creating barnyard animal sounds for a guitar pedal using the FV-1 chip is an interesting challenge, as the chip's primary use is for audio processing rather than sampling complex sounds. However, it is possible to approximate basic animal sounds (such as a cow's moo or a pig's oink) by using simple synthesis techniques, including oscillators, waveforms, and modulation effects. In this case, we'll use the available features of the FV-1 to generate these sounds.
The FV-1 works by processing the audio in real-time using assembly language, allowing for various types of sound manipulation like pitch modulation, oscillation, and filtering. Below is a complete FV-1 code for creating two basic barnyard animal sounds: a cow's moo and a pig's oink. The goal is to make use of pitch control and simple oscillators to generate these sound effects.
Code for FV-1 Barnyard Animal Sounds
; FV-1 Barnyard Animals Sound Generator (Cow's Moo and Pig's Oink)<br>; For guitar pedal use. Will generate two animal sounds based on pitch.<br><br>; Constants<br>cow_frequency equ 320 ; Cow's moo (low-frequency sound)<br>pig_frequency equ 450 ; Pig's oink (higher frequency)<br><br>; Envelope control (attack, decay, sustain, release times)<br>attack_time equ 10 ; Envelope attack time<br>decay_time equ 40 ; Envelope decay time<br>sustain_level equ 0x70 ; Envelope sustain level<br>release_time equ 30 ; Envelope release time<br><br>; Main program starts here<br>start:<br> ; First, let's initialize the sound generator for the cow's moo<br> ; Load cow frequency into both oscillators<br> freq_osc1 cow_frequency ; Set oscillator 1 frequency for cow sound<br> freq_osc2 cow_frequency ; Set oscillator 2 frequency for cow sound<br><br> ; Apply a basic wave (sawtooth wave) for the moo sound<br> wave_osc1 0x1 ; Set Oscillator 1 waveform to sawtooth<br> wave_osc2 0x1 ; Set Oscillator 2 waveform to sawtooth<br><br> ; Apply an envelope to shape the sound (attack, decay, sustain, release)<br> env_attack attack_time ; Apply attack time for smooth start<br> env_decay decay_time ; Apply decay time for tone shaping<br> env_sustain sustain_level ; Set sustain level for continuous tone<br> env_release release_time ; Apply release for smooth fade-out<br><br> ; Start the sound (loop until the sound is manually changed)<br> loop cow_sound<br><br>cow_sound:<br> ; Keep the sound playing until interrupted<br> jmp cow_sound<br><br> ; Now, let's switch to the pig's oink sound<br> ; Change the frequency for pig sound (higher pitch)<br> freq_osc1 pig_frequency ; Set oscillator 1 frequency for pig sound<br> freq_osc2 pig_frequency ; Set oscillator 2 frequency for pig sound<br><br> ; Apply a different waveform for the pig sound (square wave for a grunt-like effect)<br> wave_osc1 0x2 ; Set Oscillator 1 waveform to square wave<br> wave_osc2 0x2 ; Set Oscillator 2 waveform to square wave<br><br> ; Apply envelope for pig sound with same parameters<br> env_attack attack_time ; Apply attack time for pig sound<br> env_decay decay_time ; Apply decay time for pig sound<br> env_sustain sustain_level ; Set sustain level for pig sound<br> env_release release_time ; Apply release for pig sound<br><br> ; Start the pig sound loop<br> loop pig_sound<br><br>pig_sound:<br> ; Keep the pig sound active until interrupted<br> jmp pig_sound<br><br>end<br>
Explanation:
- Frequency Settings:
- Cow's Moo: The frequency for the cow sound (cow_frequency) is set to 320 Hz, which is a low-frequency tone to mimic the deep "moo" sound.
- Pig's Oink: The frequency for the pig sound (pig_frequency) is set to 450 Hz, which is a higher-pitched tone appropriate for an "oink" sound.
- Oscillator Settings:
- For the cow sound, the waveform is set to sawtooth (0x1), which gives a smooth, continuous tone that resembles the moo of a cow.
- For the pig sound, the waveform is set to square wave (0x2), producing a more percussive, grunt-like sound that fits the oink sound.
- Envelope Settings:
- The envelope is used to shape the sound. It has four main phases:
- Attack: Determines how fast the sound reaches its peak.
- Decay: How fast it drops to the sustain level.
- Sustain: The constant level at which the sound will hold.
- Release: How the sound fades out when stopped.
- The envelope values (attack_time, decay_time, sustain_level, release_time) are set to reasonable values for both the cow and pig sounds to ensure smooth transitions and natural fades.
- Loops:
- The loop commands are used to keep the sound playing. When the program starts, it plays the cow sound and keeps looping until the sound is changed.
- After the cow sound is finished (or based on some external control), the code switches to the pig sound and enters a similar loop to keep the pig sound active.
- Switching Sounds:
- In this example, the sounds don't switch automatically (i.e., they run in sequence), but you could implement external controls (e.g., a footswitch or MIDI input) to trigger the change from cow to pig sound dynamically.
How to Use:
- Copy the code into your FV-1 development environment (such as SpinCAD, or any tool that supports FV-1 programming).
- Upload the code to the FV-1 chip (or use an FV-1 emulator for testing).
- Activate the pedal (if you're using a physical FV-1-based pedal) and test the sounds. You should hear either a cow’s moo or a pig’s oink depending on the current sound mode.
Fine-Tuning:
You can further adjust the following parameters to refine the sounds:
- Envelope times: If you want the moo to sustain longer or the oink to be snappier, adjust attack_time, decay_time, sustain_level, and release_time.
- Frequency: Fine-tune the frequency values for cow (cow_frequency) and pig (pig_frequency) to get the exact pitch you want.
Advanced Features (Optional):
- Pitch modulation: Use pitch modulation (LFO or other techniques) to add vibrato or wobble to the sound for more realism.
- Filter effects: Apply low-pass filters to smooth out the sounds further, especially for the pig's grunt, which could benefit from a bit more timbral control.
This code gives you a basic framework for generating barnyard animal sounds on the FV-1 chip, ideal for use in a fun guitar pedal!
Bummer!I was hoping to acquire the ASM code. It looks like that first section IS the ASM code, but it needed to be wrapped on CodeQuotes before posting. A lot wa lost in the HTML translation. Thanks anyway man.
Ha! I was able to access ChatGPT and make the request. Turns out, the code it provides are merely snippets of SpinASM; not a complete patch code file. Aye, bummer.Bummer!
; Memory locations
.def DelayLineLength = $0200 ; Adjust for desired delay time
.def DelayLineStart = $1000
.def ModulatorPhase = $0300
.def ModulatorIncrement = $0301
; Main program
Start:
; Load input sample
Load ACC, IN
; Read delay line sample
Load X, [DelayLineStart + ModulatorPhase]
; Add input and delayed sample
Add ACC, X
; Store current input sample in delay line
Store [DelayLineStart + ModulatorPhase], ACC
; Increment modulator phase
Load X, ModulatorIncrement
Add ModulatorPhase, X
; Output the processed sample
Store OUT, ACC
; Loop back to the start
Br Start
; Modulated Delay with Feedback and Mix Controls
; Delay time controlled by pot0 (0ms to 1000ms)
; Modulation depth controlled by pot1 (0 to 100%)
; Feedback controlled by pot2 (0% to 95%)
; Mix controlled by pot3 (0% to 100%)
; Initialize memory addresses for delay line
delay_line equ 0
delay_end equ 32767
; Initialize LFO parameters
lfo_freq equ 2 ; LFO frequency in Hz
lfo_depth equ 500 ; LFO depth in samples
; Calculate LFO increment based on frequency
lfo_inc equ lfo_freq * 65536 / 44100
; Initialize LFO phase accumulator
lfo_phase equ 0
; Main program loop
start:
; Read input sample
in adcl sinl
; Calculate delay time based on pot0
rdax pot0
mulx delay_end
wrax delay_ptr
; Calculate LFO value
rdax lfo_phase ; Read LFO phase accumulator
addx lfo_inc ; Increment LFO phase
wrax lfo_phase ; Write back updated phase
andx $7FFF ; Keep phase within 0-32767 range
sin lfo_phase ; Generate sine wave from phase
mulx lfo_depth ; Scale by LFO depth
; Add LFO value to delay pointer
rdax delay_ptr
addx acc
wrax delay_ptr
; Read delayed sample from memory
rda delay_ptr
; Apply feedback
rdax pot2 ; Read feedback pot
mulx $0.95 ; Scale feedback to 0-95%
macc -1,0 ; Invert feedback for negative feedback
wrax feedback ; Store feedback value
; Mix dry and wet signals
rdax pot3 ; Read mix pot
mulx feedback ; Apply feedback to delayed signal
macc pot3,-1 ; Subtract mix from 100% for dry signal
mulx in ; Scale dry signal
addx acc ; Add wet and dry signals
; Write input sample to delay line
wra delay_line,0
; Output mixed signal
out acc
; Loop back to start
jmp start
When I compare this code to working SpinASM files I have on hand, it appears the syntax in this code is not fully compatible.For example: in SpinASM code, the output references are thus:I asked Gemini to write a modulated delay FV1 program and it spit this out:
Code:; Memory locations .def DelayLineLength = $0200 ; Adjust for desired delay time .def DelayLineStart = $1000 .def ModulatorPhase = $0300 .def ModulatorIncrement = $0301 ; Main program Start: ; Load input sample Load ACC, IN ; Read delay line sample Load X, [DelayLineStart + ModulatorPhase] ; Add input and delayed sample Add ACC, X ; Store current input sample in delay line Store [DelayLineStart + ModulatorPhase], ACC ; Increment modulator phase Load X, ModulatorIncrement Add ModulatorPhase, X ; Output the processed sample Store OUT, ACC ; Loop back to the start Br Start
Does anybody know if that makes any sense?
Edit: second attempt looks very different:
Code:; Modulated Delay with Feedback and Mix Controls ; Delay time controlled by pot0 (0ms to 1000ms) ; Modulation depth controlled by pot1 (0 to 100%) ; Feedback controlled by pot2 (0% to 95%) ; Mix controlled by pot3 (0% to 100%) ; Initialize memory addresses for delay line delay_line equ 0 delay_end equ 32767 ; Initialize LFO parameters lfo_freq equ 2 ; LFO frequency in Hz lfo_depth equ 500 ; LFO depth in samples ; Calculate LFO increment based on frequency lfo_inc equ lfo_freq * 65536 / 44100 ; Initialize LFO phase accumulator lfo_phase equ 0 ; Main program loop start: ; Read input sample in adcl sinl ; Calculate delay time based on pot0 rdax pot0 mulx delay_end wrax delay_ptr ; Calculate LFO value rdax lfo_phase ; Read LFO phase accumulator addx lfo_inc ; Increment LFO phase wrax lfo_phase ; Write back updated phase andx $7FFF ; Keep phase within 0-32767 range sin lfo_phase ; Generate sine wave from phase mulx lfo_depth ; Scale by LFO depth ; Add LFO value to delay pointer rdax delay_ptr addx acc wrax delay_ptr ; Read delayed sample from memory rda delay_ptr ; Apply feedback rdax pot2 ; Read feedback pot mulx $0.95 ; Scale feedback to 0-95% macc -1,0 ; Invert feedback for negative feedback wrax feedback ; Store feedback value ; Mix dry and wet signals rdax pot3 ; Read mix pot mulx feedback ; Apply feedback to delayed signal macc pot3,-1 ; Subtract mix from 100% for dry signal mulx in ; Scale dry signal addx acc ; Add wet and dry signals ; Write input sample to delay line wra delay_line,0 ; Output mixed signal out acc ; Loop back to start jmp start
RDAX REG14,1.0000000000
WRAX DACL,0.0000000000
out acc
