Robert Reverse Engineer Nov 4, 2022 #1 Mystery Meat Overdrive Attachments MysteryMeat.txt MysteryMeat.txt 614 bytes · Views: 256
Locrian99 Well-known member Nov 5, 2022 #2 4u7 Film or electro.... I'm assuming non polarized electro would be better than polarized here?
Robert Reverse Engineer Nov 5, 2022 #3 The polarity is marked on the PCB so either should be fine. Last edited: Nov 5, 2022
Fingolfen Well-known member Nov 11, 2022 #4 Does this use the standard 5 pot drill template with LED between the upper two?
Robert Reverse Engineer Nov 11, 2022 #5 Almost. It's the 5 pot template but the LED is above the footswitch. So basically the 6-knob template without the center pot on the top row.
A ac30irons Active member Jul 5, 2024 #6 @Robert hey there, will the lead solder template be ok ( minus top middle )?
Robert Reverse Engineer Jul 5, 2024 #7 ac30irons said: @Robert hey there, will the lead solder template be ok ( minus top middle )? Click to expand... Yes, omit the toggle switch as well.
A ac30irons Active member Jul 6, 2024 #8 Robert said: Yes, omit the toggle switch as well. Click to expand... Thanks so much
