knucklehead
So . . . . .
I have a unique wiring harness in my instruments. It's a three single coil pickup configuration - the center pickup is always on, and the neck and bridge are opposing coils so that when either bridge or neck is combined with the center pickup it cancels hum.
My conundrum; I use a blend pot on the outside coils to sweep between them then combine the blend pot output in either series or parallel with the center pickup. There are currently two off-shelf blend pots readily available - a conventional L/R where center detente is full volume on both sides, and stacked volume pots with center detente having half-signal. The second is a non starter as half volume is too quiet and the center coil overpowers the combined output of the other two. The first yields faint but present 60 cycle hum because of the unity gain of the combined output of the outside coils. I am tinkering with resistor values to see how much I need to diminish output at center detente to eliminate hum and keep consistent volume on the sweep.
I know Bourne will do custom pots as I have had conversations with them over such things in the past - are there other players I should consider?
