bschobs
If you were to troubleshoot a pedal that has only a wet signal when engaged, are there some common places to start? Dry signal is normal when in bypass. This one happens to be a Dark Rift Delay. When engaged I am able to adjust the mix and hear the wet signal but the dry doesn't come through at all.
I'm expecting to need to go through all of the troubleshooting steps but thought I would throw it out there in case there are some things to try first that I am missing.
Thanks!
Thanks!
