Nobelium - tube bass preamp project
I would guess that it would be the Super Bright pink LED SKU: A-4732 from Tayda, whatever LED you use make sure it is Super Bright with very high MCD rating.
You can increase the brightness of the LED by using a lower value dropping resistors R4 and R6, you can lower the resistor as low as 510 ohms and still be within the LED's specs. I think I often use 820 ohms for my LED resistors on my builds.
The resistance will vary with the LED choice also, the pedal can take 12v and the pink LED has a voltage drop of 3.2v so you have 8.8v over the resistor, if you use a 820 ohm resistor you have a current of 10.7mA going through the LED
12v-3.2v= 8.8v, so - 8.8v / 820R = 10.7mA (0.0107 Amps)
If you want to run max current which is 20mA you use 8.2 Volts / 0.020 Amps = 440 ohms.
I would never use less then 510 ohm and I prefer to go to about 10mA to 15mA in my LED's
You can also put reflective tape inside the box to reflect the LED light better of the walls but I would not go that far myself, I got some spare copper tape I use in my guitars to limit interference so I might try it one day though.
Hey All,
I have Good news & Bad News. The Good News is The pink LEDs look excellent! The Bad News is the lights are on but nobody's home...
The LEDs light up, and the tubes get a little warm so I guess the heaters are working? That seems to be the extent of it at this point. No sound whatsoever from the XLR & 1/4" outs. No magic smoke released so that's good too I guess! Everything went fine during assembly right up until I realized that I had a better switch to use for the HPF. I decided to pull the switch that I'd installed which was unwise. Pretty challenging with just de-soldering braid. I eventually got it out but I'm wondering if during that process I may have cut a trace or something... This will at least be a good learning experience on troubleshooting. :) I was careful not to leave any stray solder, trimmed all of my joints, and cleaned up with 99% isoprophyl. I'll get pics of the backside tomorrow. Maybe I need to make an audio probe? If anybody sees anything suspicious or has any tips that'd be really great.
I just checked the voltage in a few spots and the highest voltage I'm seeing is 177v. That's much lower than what Toasty was seeing when he made the Nobelium Kit video. Maybe not enough voltage to fully light up the tubes?
Thanks
Thanks Rev! That got me past at least my first rookie mistake! I'm now getting beautiful warm tube goodness through my XLR out. A couple of things are still not right though. Following the troubleshooting steps outlined in:
Thanks So Much
Hello Everyone !
I'm Fred from France.
Last week, after asking for being notifyed by Musikding when the kit will be back in stock, I finally got the email and purchased one in a rush.
Soon after, it becames unavailable again. But my order appears complete and paid. It was june 16th. Since then, no news. I tried to contact Musikding using the Contact Form, twice. But still no answer.
Is this company alive ? Please tell me it is not a scam..
Hello Everyone !
Musikding isn't a scam, a lot of folks around here order from them regularly.
Thank you for your reply. I appreciate.
Maybe the guy (Klaus ?) is overload.
Anyway, thanks to him for allowing european musicians to access diy kit, but It could be nice from him to communicate more, at least answer those who try to contact him via his contact form.
EDIT : I've just received a mail - my kit is underway. I don't know if Klaus is coming by this forum, if so : Thank you Klaus !!
Klaus does seem to get overloaded and can be slow to answer emails, but I promise he is around and will always take care of you eventually.
Also Klaus has an open order for more Nobelium PCBs which I will be shipping out this week.
Klaus is awesome. He does get very busy and doesn't respond like a big company would.
But he provides a great inexpensive service, makes any problem right (eventually) and provides extras one wouldn't normally expect.
I buy a lot of Musikding kits...
