Hmmm. I have a semi-working build for the Mesmerizer. The sound through the board without dialing in the effect is OK. The volume pot works. The depth control and rate control change the intensity and speed of the flashing LEDs. I am using an old XR2206 IC that I know is good, and it is working. I get a sine wave output of about a 2V range at pin 2 of the XR2206 that does not modulate the sound when I adjust the rate and depth controls. When I open the connection between pins 13 and 14, the output at pin 2 changes to a triangle wave with a higher voltage output. I do get a pulsing in the sound from the triangle wave, but only at its peak signal level. It also only makes the sound louder and not quieter than the unmodulated signal.
I double checked part values using my DMM for all resistors before they were installed, and confirmed caps matched the values on the build document and what was printed on the board when they were soldered into place. I have gone back over the solder connections and reflowed them from each side of the board.
For the active parts of the circuit, I have swapped out the TL072 and also subbed the 2N5457s with J201s and NTE458s without success. I have not tried to switch out or sub the 2n5458 transistors yet, but that is next on the list.
Any suggestions on isolating things to check is appreciated.
