J JimL Member Jan 13, 2026 #1 Build docs - I am unsure what this section I am pointing to means. Need some help for me because I am new. Green Scream Machine Attachments Screenshot 2026-01-13 at 6.17.25 PM.png 5 MB · Views: 44
Erik S Well-known member Jan 13, 2026 #2 Looks like you have the option of 1n4148s using the outer holes, or LEDs using the inner holes. LEDs being Light Emitting Diodes are sometimes used inside a pedal as clipping diodes instead of on the outside for making light.
jimilee Well-known member Jan 13, 2026 #5 JimL said: Should I follow the same positive negative on the PCB? Click to expand... Yessir
Erik S Well-known member Jan 13, 2026 #6 JimL said: Should I follow the same positive negative on the PCB? Click to expand... Yup. Just like the picture. Square pads get the stripey ends if you go with the 4148s, short leg if you go with LEDs.
Erik S Well-known member Jan 13, 2026 #7 Oh, I see now that left-right is flipped in the picture. Yes, follow the PCB.
