NPN Sunflower fuzz build
estimated_eyes
Hey all,
I'm building the Sunflower Fuzz but using NPN silicon transitors instead on PNP.
I found another thread in which the following necessary changes were provided:
Omit C5 and IC1
Install jumper from Pin 8 to Pin 5 of unpopulated IC1 (this will give you a +9V rail, no need to fool with SW)
Reverse all remaining electrolytics
Install jumper across pads 1 and 2 of Sundial control.
Ensure pinouts of Q1 and Q2 are correct
I'm an hoping someone will be able to clarify for me....
Is the Sundial pot completed omitted from the build when using NPN transistors?
Or is the Jumper across pads 1 and 2 of the Sundial pot done with the pot mounted to the PCB?
Thanks for any help!
