The pic does look like that but I double checked, longer peg from DC jack goes to positive.It looks like you have your positive and negative wires backwards at the dc jack to pcb pads.
Thank you. Dumb question, If I use a breakout board, is everything but the bypass (5th point on PCB?) the same?The wiring on this one is a little different.
It isn't a buffered bypass effect and isn't designed to work with that breakout board.
