finebyfine
This ocelot build is giving me a faint distorted signal sort of “behind” the octave signals and dry signal. More noticeable on higher notes up the fretboard but it’s always there a little bit. It otherwise works exactly as expected.
Not sure what to be looking for for trouble shooting.
All ICs are from Tayda.
Ge diodes are a matched pair with Vf of 0.395v at 5mA.
2SK30As have Vgs(off) of -2.35v, Vgs(on) of .5v, gfs of 3mA/V, Idss of 3.50mA, Rds(on) of 570 ohms.
2N3904 has an Hfe of 329, Vbe of 0.764V, Vcesat of 0.026V.
I imagine the 2SK30As are the issue but I don’t know what to be looking for in a substitute or different 2SK30As. I have more on the way from Tayda. I have most of the common N channel JFETs we use in pedal building on hand and some 2SK193s.
I also have plenty of other germanium diodes if a different Vf is needed.
Appreciate any help and guidance, thanks!
Edit:
- tried subbing out j201s
- tried different tl072s
- tried tl022s in place of tl072s in the places where they can work
Edit:
- also tried replacing ge diodes with bat41s. no difference
- Shielded wire helps a lot, but still kind of there
Edit:
Edit:
