SOLVED Ocelot Octave Funny Issues
dj-scully-bass
Hey guys, new here! I've built a handful of pedals without issue, but my white whale has been what is basically a copy of this build:
I managed to get one Ocelot built according to the docs no problem. Then I tried to do a second with the 2 knob job and left out the Oct 2 pot and it worked great yesterday, but after trimming some wires to make it fit in the box, I'm not getting any signal when engaged AND it's making this funny little noise when I plug it in. I removed the 2KJ altogether and cleaned it up to test it and I'm still not getting anything. I gotta imagine that noise has something to do with the whole thing not working (did I short out and destroy an IC?)... but maybe not! I tried searching to figure out what might be causing it, but search terms for 'bloop when powered' was not getting me anywhere lol
Thanks in advance for any insight!
EDIT: My functioning Ocelot also makes the same noise when I plug it in while it's engaged. Anyone else notice this? It's not the end of the world for my purposes as long as it's not hurting anything...
350357492_6070886696342531_2534554226272341582_n(1).jpg 350243127_2266417920413416_8548985086599459070_n.jpg 350361343_606054304836456_5473720576425276091_n.jpg
Hello the team
I have problem with the PCB and the pin2 (the gate) on the Q3 I lost the soldering connection
I tried as marked on the jpg to solder to the R20 and the R19 (blue and orange threads) but nothing changed and it still doesn’t work
Can you tell me please where the 3 pin are linked espacially ht epin2 the gate but if uou can also tell me if my schema is correct
can you test that with a multimeter..i wrote to pedalpsb but no one respond me
by advance thank you
I uploaded on my dropbox a video to show the problem on the attached files
here is the link https://www.dropbox.com/s/i7yxhjnf78myuqk/20230628_215748.mp4?dl=0
As demanded on the jpg "ocelot Q3pin2" canb you show me where i have to solder the pin 2 of the Q3 on which component ?
by advance, thank you
my ocelot works perfectly but the led wont turn on and im getting fuzz here and there
bad pots?
this pic was before i added the 68k
