Octagon: Magic Carpet Ride
Chuck D. Bones
Circuit Wizard
I finally finished my Octagon. I add two features: a toggle switch to select between the internal FV-1 programs or the EEPROM and an expression pedal jack & select switch (white knob). The expression pedal can override any one of the three CONTROL knobs, or none of them. Some very cool sounds in this box. I want to thank K Pedals for guidance & encouragement with my initial foray into acrylic pouring.
All wired up and getting tested prior to painting. Worked from the git-go, no troubleshooting req'd! That 1K CC resistor hanging in the air is for short-circuit protection on the 3.3V expression pedal bias.
Fit check prior to final wiring. I had tried to fit this into a 125B, but no dice.
Input & Expression pedal jacks.
Far out man , very groovy looking CDB !
I knew you couldn't do a pedal un modded , awesome build Chuck !
After reading magic carpet ride ...ill never get that song out of my head today...lol
Mike
All wired up and getting tested prior to painting. Worked from the git-go, no troubleshooting req'd! That 1K CC resistor haning in the air is for short-circuit protection on the 3.3V expression pedal bias.
Amazing work man!!!
Inside and out!!!
Hi Chuck! I don't think I understand how you used the 1k resistor.
You're just connecting/disconnecting lug 2 of the pots with the stereo jack right? Then another lug is ground, and the other 3.3v?
Lug 2 of the three CONTROL pots are connected to or disconnected from the Expression jack by the 4 position rotary switch. The 1K resistor is in series with the 3.3V supply in case I accidentally plug the wrong thing into the Expression jack and short the 3.3V to ground.
That looks sick!!!!
