Right on. I’ll have to see what the diff would be to have 20 small breakouts vs a 5x4 panel.Mouse bites to connect the boards together (just small drill holes in a row). Sometimes it can be cost saving but JLPCB does charge extra for it.
BTW, on my last order JLPCB charged me sales tax which is a first. Don't know what's going on with that.
Right on- that clear things up a bit. I would think that with the volumes you produce they charge by total area? I’m thinking more about my $2 special for 5 and making panels to save a few bucks.With JLCPCB it usually isn't cost effective to panelize multiples of the same PCB, especially considering you'll have to break them apart and you're left with rough edges (if you've ever gotten FR-4 splinters you know).
I panelize 3PDT breakout boards and small things like that because it makes it easier to count and ship multiples. Getting a box of 10000 individual 3PDT breakout boards can be ... fun.
If you do panelize multiples of the same layout you can usually avoid the charge by ordering 20 or more panels, although at some threshold there is a surcharge for "excessive number of slots" if you have any non-round holes. Regardless of how many are in the panel it is still considered a single design as long as they are all exactly the same.
For something that ships as a set like the Kliche Mini above, I panelize for convenience, because otherwise I will forget your breakout board.
These do cost a little extra but it makes it much easier to ship (and keep up with) something that requires multiple parts.
I hand draw those panels. There are programs that can automate the process but I was never happy with the results and I wanted the surrounding frame to make them easier to ship. It's a bit of an involved process but I think the end result is worth it.
Is there a standard size and spacing for them?If you use mouse bites I think you should be OK.
If you use v-scoring they'll hit you with a surcharge for less than 20 pieces.
jlcpcb.com
I noticed that too the other day.I never noticed it before, but I just checked the small 10 pcb order I made a couple of days ago and I did get charged 50 cents for sales tax, plus a 50 cent paypal fee.
bumping this thread
I'm looking at getting some adapter boards done, and wondering if it's cost-effective to panelize with JLC, or just get these done at OSHPark, since they're so small (measured in mm)
Also thinking about doing pick and place if I went with JLC to save time since it's two components (the resistor is TH here, but I'd change it to SMD)
