SOLVED Paragon Build Issues
Joli65
Just finished up this build. I didn’t do any mods but am experiencing switch pop on both sides and the LED on the left side doesn’t work. I’ve tried a couple of different LED’s and no change. The right LED works fine and the pedal itself functions as it should. Any ideas for either issue? Thanks!
Edit:
I filled in the rest of the 3pdt switches with solder and that resolved the LED issue and switch pop on the right side. I do still have switch pop on the left side though.
Nice, clean looking build!
I get switch pop on my Paragon build also. I'll be watching this for possible solutions.
Alright I’m going to call this 95 percent solved. There was a post in the below thread about adding a 10k resister to the switch as shown in the pic. It took the pop from loud to just barely there. I tried 15k to see if that would take away more but it was less effective than the 10k.
