Paragon Build Report
swelchy
I’ve put this one together from start to finish this weekend… I’ve built a couple in the past that just didn’t pan out… This one is fine if you stack both sides reasonably.. if you crank both sides it’s squeals and oscillates… tried switching out the charge pumps and three different types of dual op amps… No luck… just gotta back down the gain. Right side is low gain and left side is high gain.. used OA1154 diodes in the hard clipping section. IMG_7026.jpeg IMG_7028.jpeg
