clipped_diode
Click here to see the "completed" build outside of an enclosure.
I've only done three kits before sourcing parts for this PCB, so I'm still relatively new to DIY pedals. I expected some trouble from the finished pedal because throughout the build several pads popped off and the copper plate is slightly exposed in a few spots. (Ultimately, I don't think the pads caused a problem because in each instance at least one side still had a pad.)
I am using an audio signal probe to diagnose. This post is probably a little premature because I'm still trying to understand the schematic, but here's what I know right now.
EDIT: Updated title to reflect current issue. It's the distortion switch that kills the signal. Octave switch does nothing. I got the boost side working after replacing a part.
- True bypass works.
- The effect seems to work. I get a heavy distortion (almost 8-bit velcro ) and an octave sound. I'm not sure how much this pedal is meant to clean up but even with distortion all the way off it is still heavily distorted. EDIT: Playing with a guitar it is clear that this is way more "gated" sounding than it should be. I have to strum HARD for a short spike of sound that quickly falls off. (Like velcro settings on Fuzz Factory or similar.)
- Turning the octave knob down lowers the total output volume.
- If I switch the octave switch, the output dies.
- If I switch the boost switch, the output dies.
