YourGuitarist
Hello,
I am working on designing my first PCB with PCBmount pots (was originally wiring offboard panelmount). I would like to know any tips or precautions people have when working with PCBmount?
In particular, I am curious if I mix PCBmount pots with solder lug switches, will there be vertical clearance problems?
My pots are mounted on the backside of a two layer. The pots are 9mm Alpha RD901F-40-15R1-value. The board uses thru-hole components including 16V 470uF electrolytics (the tallest component).
The enclosure is 125B.
