Peavey F800B clone development almost no signal
Pollyp
Hi y’all,
Sorry if this is the incorrect forum to be posting this in. I am currently breadboarding a clone of the peavey f800b preamp, just the three band eq and distortion circuit for now. I got all the (I believe to be correct) components, which meant for some of the caps I had to use ones rated for a much higher voltage as I wanted to use exactly the same values used in the schematic. When it was all said and done and wired up however, I am getting very little to no signal from the output, and the gain of the output seems to go up and down just by me touching the potentiometers, even when I ground them with alligator clips. It seems like the pots are working as they should with the limited amount I can hear, but something is definitely off. I went through all the connections and triple checked everything was matching the schematic and still, an essentially broken output. Attached are the original schematics, and the adapted original schematics that I edited, as I wanted the distortion circuit to match the early version of the amp (a friend who has cracked one open showed me what the difference was), and another similar schematic to mine that I found on another forum, as well as multiple pics of what my breadboard looks like so far. I can upload a parts list from Digikey if needed as well. Thank you!
...the gain of the output seems to go up and down just by me touching the potentiometers, ...
Seems like a grounding issue.
Sometimes breadboard-tracks can be faulty.
What are your mods? The schematics you've posted don't appear to be doctored in any way... I don't see any edits — your copy of Ryan's CVLT schematic matches my own...
The schematics I edited were the original peavey schematics, I removed the clipping diodes, and the foot switch circuit, as well as the 6 band eq, and I moved the rc filter and signal attenuator to the output of the main circuit. It’s the file name: “f800 early without eq”. I edited that file as I wanted to retain as much of the original circuit as possible, and I found errors with Ryan’s.
Are you running it at 24v?
Yes I have a 24v center positive psu, rated for 800 mA, and I measured the current draw to be around 0.4 amps.
Coolio. Your schem looks professional ...
...When I edit schematics, it's with little coloured arrows and scribbles. 😸
Just woke up... was looking at this after letting the dog out in the middle of the night.
I bet you're far more capable at trouble-shooting than I am. Still, a second or third set of eyes can sometimes be of help...
Yeah any help would be greatly appreciated!
I’m probably like the least professional guy to be doing this type of stuff 😂, this is my first breadboard in a while, and I’m a comp sci major so this is a lil out of my element, although I am going to be taking a circuit building course next year so I’m excited for that, figured I’d do a little project like this as a refresher before I hop into that course.
