tfTom
Hello everyone! I apologize in advance for this wall of text, but I want to be as thorough as I can. I am building my second pedal ever and I've gone through quite a bit of a hassle trying to troubleshoot it. The main issue I've had with the pedal is the output volume is very low. It's way quieter than the clean bypass signal. All knobs seem to function properly, the output is just really low.
This was my first time ever troubleshooting a pedal, so I tried doing my research first, but I'm pretty stumped at the moment. I made a quick audio probe and looked around the circuit, everything seemed to work perfectly until I reached R12 on the circuit. On one side, the signal was pretty loud, but on the other it dropped down dramatically, I'm not entirely sure how much it is supposed to drop since R12 is a limiting resistor from what I have gathered, but it did seem like a very big drop in volume.
After the audio probe I decided to check the voltage for each of the Transistors as well as R12, so here is the list.
Q1
Collector - 4.61
Emitter - 0.14
Base - 0.7
Q2
Collector - 3.78
Emitter - 0.07
Base - 0.62
Q3
Collector - 0.4
Emitter - 0.38
Base - 1.04
Q4
Collector - 4.46
Emitter - 0.94
Base - 1.43
R12 went from 3.78V to 1.04V
I'm pretty sure there's something going on with Q3, I'm not too sure if its fried or if the resistor has something to do with it, but I don't have a spare to test the circuit with a new one. Any pointers are appreciated. Thank you!
I attached some pictures of the (sloppy) solder job i did, there are a few scratches on the back of the board but I'm pretty sure it's all cosmetic. There's also quite a bit of flux residue that I haven't been able to clean off entirely.
Q1
Collector - 4.61
Emitter - 0.14
Base - 0.7
Q2
Collector - 3.78
Emitter - 0.07
Base - 0.62
Q3
Collector - 0.4
Emitter - 0.38
Base - 1.04
Q4
Collector - 4.46
Emitter - 0.94
Base - 1.43
