Coda
I am thinking of adding a toggle (SPDT- on/off/on) to a Harmonic Percolator Injust built, in order to choose between either of the diodes, or no diodes. I could use a second opinion. As I see it (which is almost always the wrong way), I would connect the diode to one leg (? I can’t remember what they are called) of the switch, and then wire the middle lug (I remembered!) to to be, where the other end (negative) of the diode would go, correct?
