Okay - so I just built up a Phase II phaser and it turns on, passes signal in bypass, etc. I subbed a couple of parts since Tayda was out of A25k pc mount pots, so I used an A50k for the rate knob and they were also out of TC1044 voltage ICs, so I used an ICL7660 instead. When the effect is engaged, there is only a subtle hint of phase and the internal yellow LED doesn't seem to pulse at any rate no matter how I set the trim pots or turn the rate knob. Also - when the rate knob is maxed, there is a high pitched whine.
Any ideas on what might be causing this?
