Blank
This is a rat hole and then some. I have a modified rate 2. 3 clipping mods and a switchable ruetz mod. Got 2 rats with led 914 switching mods, then I bought a fat rat. Then I started with the Brat / Roadkill rat. That board should be here Monday. It has clipping in the feed back loop. I’m working on another one with mosfet clipping similar the fat rat but with two misfits instead of just one. There are so many variations out there. The mosfet I’m working o. Will have 2 options and a diode lift for opamp clipping.
I cheated and used the AionFX Helios PCB for my Rat build (https://aionfx.com/project/helios-vintage-distortion/). I used a LM308N op-amp for authenticity. However, for the clipping diodes I altered the specs a little bit. The cool thing about the Helios is that it has a three-way switch for diode selection. A set of LED's is always kept inline for hard clipping. By default, AionFX specs it out with switch setting for a pair of 1N914 diodes and another for two pairs of 1N914's. I nixed the two pairs in favor for a pair of 1N34A's. So, basically, you get the standard 1N914 clipping (basic Rat flavor), LED clipping only (Rat Turbo?), and GE diodes (Dirty Rat?). Pretty much covers all the Rat most people would want I think. :D
My BB sounds even better after putting that 30p from 1-8 instead of 1-5 ;). I'll put some groovy pics of squiggly lines my scope put out in the Test Kitchen...
Jeff, I used 1N4148s, a 2N5457, and a LM308N.
Derek, have you decided on what mods?
2N5457 here as well. With the LED hard clipping in-line after the main clipping diodes, I would imagine the 1N914’s sort of clip in a similar manner with the LED’s. They’re there no matter what so the kinda clip a bit with the other diode selections…at least I think they do. 🤪
I built two Rat pedals, having never played one. I tried to basically do the same thing you are doing. I installed sockets everywhere I thought a worthwhile mod could be installed. The differences are small, but I keep going back to one pedal. I thought I'd be tinkering with these a lot, but I haven't really touched them.
But PCB boards are cheap, and Rat boards are easy to find. Wouldn't it be fun to build several and use plugs for the hardware (Like an Auditorium Test Platform) so you could swap versions into your enclosure.
Reactions: fig
That's why I went back to the Rat. Full circle. Push it with a tube screamer and it really sings.
I’m planning on having @thewintersoldier build it for me in the New Year.
