Feral Feline
In the era BP (before PedalPCB) I bought a "few" *(hundred) GuitarPCB ones, Barry had a group-buy/sale so I went a little nuts and ordered a bunch, a BIG BUNCH.
Lots of extra ground-pads, and the 2-colour LED option can be useful for some builds, such as dual-circuit builds or dual-control builds.
I like to mod them, like if thrown in the middle of a circuit for whatever reason, you can cut the bypass trace easily (below lug 6) and throw in a resistor between pins 3<>9.
I tend to cram when building 1590A (well, any size enclosure), so GPCB's actually not that great for that application — the bottom corners are angled, but they really need to be curved to fully get around the screw channels of the 1590A and utilise that last 1/2 a millimeter that I all too often need.
So for 1590A I use other 3PDT boards that have that curvature in the corners or none at all (unless there's plenty of room for one of GPCB's). I kind of collect breakout boards from various suppliers, just to see what they do differently and to see what I like. Haven't come across a need for a dimmer-trimmer in any builds, but I might, and even then, could just wire up a trimmer. Some have weird extensions off to one side to accommodate the trimmer or some other thingermajigger, but the more compact, the better for me.
Most breakout boards I've seen have the standard in/out ala the GPCB breakout boards, whereby:
POLE 1
Pin 1 to board
Pin 2 input from jack
Pin 3 bypass to pin 9
POLE 2 — for LED switching
POLE 3
Pin 7 from effect
Pin 8 out
Pin 9 hardwired to pin 3
WHAT I'D LIKE TO SEE...
...Is a breakout board that has the curved corners, a few extra ground pads, CLR & LED capability and WIRED AS PER MARC SKREDDY does it, as shown in MadBean's 3PDT wiring doc. It's Fig 13 in this PDF: https://www.madbeanpedals.com/tutorials/downloads/MBP_FootswitchWiring.pdf
POLE 1
Pin 1 to LED+
Pin 2 Ground AND hardwired to pin 3
Pin 3 Hardwired to pin 2 and pin 6
POLE 2
Pin 4 Input from jack and jumpered to pin 9
Pin 5 to circuit-board's input
Pin 6 hardwired to pin 3 (Ground)
POLE 3
Pin 7 from effect circuit
Pin 8 out
Pin 9 hardwired to pin 4
Anyone know of any breakout 3PDT boards wired like that? Althought I've got a few Madbean breakouts (IIRC), I don't even know how they're wired. Does Madbean do the Skreddy method on his own breakout boards?
When I get better at this game and can wire a 3PDT tidily, and I run out of my stash of breakouts ... I won't need them anymore?
Cheers,
FF
POLE 1
Pin 1 to board
POLE 3
Pin 7 from effect
Pin 8 out
POLE 1
Pin 1 to LED+
POLE 2
POLE 3
Pin 8 out
Cheers,
FF
