blueimpala
I just finished building the Muffin Factory and it looks great and sounds good too... I think? If I didn't know what kind of pedal it was supposed to be, I would say that it sounds good and it's definitely a pedal I would play. However, knowing that it's supposed to be a muff, I'm not sure that I nailed it. Even with the sustain and volume all of the way up, it doesn't sound anywhere near as saturated as any other muffs I've played (which have been mostly modern ones). At the moment, I'm comparing it directly with my EHX Big Muff Nano. I'm very aware that all of the different setting choices effect the sound, but I've played around with them quite a bit and can't get anything close to that all consuming wall of fuzz that I have come to expect out of a muff.
My main point of anxiety is probably the GE transistors. They have HFE of about 40, though I know the build docs suggest HFE 55-65. I tried, but that's what came in the mail. Should I try some new transistors?
I'm also wondering about the LED clipping: When I have LED clipping on, the LEDs are barely lighting up. Is this expected behavior? I'm used to seeing clipping LEDs glow pretty bright when activated.
Thank you for any guidance and help that can be offered!
