I'm have a build on process & I'm not sure about the orientation of the 90 degree pcb mount pots . should the lugs of the pot be facing up or down towards the footswitch end ?
The square solder pad on the PCB is (usually? Always?) pin 1 of the pot. So if you are holding the PCB the right way up to read the writing the pots generally point up away from the pins.
