Synchrony Pedalworks
Wow! This is a great pedal. It really works well with my set up with a Fender Vibrochamp clone, Charvel super Strat and Fender telecaster deluxe.
The build is straightforward, but the 1.5 uV caps were a little of a pain to get. In hindsight, I should have just installed some parallel caps for that value. I did use parallel resistors to get my 82 ohm resistor, because I forgot to order that value.
The art theme is Robert Johnson and the Crossoads. As usual, I used a metal foil and the Cricuit machine. I had to do a lot to get this image to work, but I think the time paid off.
The demos were some quick renditions of John Mayer songs. With Belief, you will hear this pedal stacked with a Kliche (Klon), and this occurs near the end. I did not time the foot stomp well, so it will be apparent. . The pedal, with the Kliche, really nails the sound on the record.
