Great. Thanks!Measure your 100uf's with a DMM, you have to wait a bit for it to read full charge & see if you can get the highest.
I use Nichicon & Rubycon & they get as High as 110uF which is in spec for a 120!
Put the highest in C102!
You should be fine, they’re just powering filter caps. You shouldn’t hear any difference. I usually stick with 100uf or sometimes as low as 47uf, depending on the circuit.Can I use 100uF instead 120uF? I keep forgetting to order them and my patience has now come to an end.
@PedalPCB on the actual blues power PCB there is a transistor listed as Q1, wondering why it's not showing on the powder blue?
