ICTRock
I've soured on the hater contest so let's switch gears and post an inventory-only build over here just to fuck with them.
I happened to order the pcb back on PPCB's b-day and everything else got pulled from inventory I had lying around this morning.
I went with a DAM Meathead Dark and I started by pulling out a BC182L (Q2 in the meathead) and measuring hfe on the Atlas. I then went over to my bag of Motorola 2N3904 and found one that matched and another that came in at 75% of it for Q1. I chose not to use the BC182L because the pinout is janky. The only part I didn't have was a 1/4 watt 120K resistor. I had it in 1/8 watt and since I was using 1/8 watt for the 1K gain resistor to avoid standing the resistor on end I felt it was an OK sub all things considered.
As I was signing the bottom plate, I told my youngest (13 F) that I needed a name for it and she chose "Ass Wrecker" and so it is.
