Precipice Overdrive
Quentin
Having issues with this overdrive I just built. Not sure what the issue is. I gone back over the build plan and didn’t see anything out of the way. I have a clean bypass signal but when the pedal is engaged I have nothing. Any help or tips would be appreciated. Thanks.
Not seeing anything in the pics.
My process would be:
Check the DC voltage at pin 8 (should be 9v).
Use an audio probe to check for signal at various points in the signal flow.
That looks right to me.
You don't have the volume all the way down do you?
Other than that I don't see that looks like it should be wrong.
I'm with @phi1 - time to start probing for voltage and audio.
Especially since you don't have an LED confirming that voltage is present, that could be a good place to start.
Nope made sure volume was up. And tried adjusting the pots but nothing. I’m scratching my head on this one. On a side note I built the same pedal using a new pcb and it works fine. Not sure what I did wrong on this one though.
