SOLVED Pro-10 Dual Overdrive Not Working--Build Docs?
greypilgrim76
Hi All,
So I just got my Pro-10 board populated and (very tightly) installed in the enclosure. When I plug it in, both LEDs work, and I'm getting bypass signal, but no sound from either side engaged. I've got an audio probe and am happy to start troubleshooting, but I can't seem to find a schematic or other build docs anywhere. For assembly, I just followed the component values listed on the PCB silk screen. I'd read previous threads saying to just use the components from the Blue and Green drive docs, but I ended up having to pull some components not listed on either of those, and I also had some left over on the Green parts list that didn't get used. So, I really have no idea how to troubleshoot without a schematic and a build doc with part positions labeled (R1, D3, etc.) Any suggestions? (Or documents?)
Gracias!
I did some searching and found this post with the full schematic
Nice! Not sure how I missed that. That schematic should get me a lot further down the troubleshooting road. I don't suppose anyone has the PCB image with the components labeled using R2, D1, etc.? I can use the image of the PCB itself on the website with the component values themselves, but there are enough duplicates I'm not sure which components fit where in the schematic at times. (Multiple 47k reistors, 1u film caps, etc.)
Neither circuit is huge. Test with the probe at your active points that should narrow it down. Have you checked your voltage on ic’s to verify those look right?
both circuits are seperate with seperate ins and outs. If neither is working its likely a wiring issue or a power issue.
And check the classic is in plugged in to in, im notorious for this one
So just a quick update. I took the PCB out of the enclosure, attached it to an external power jack, and started through the circuit with my audio probe based on the schematic and component diagram you guys provided. I actually managed to get sound all the way to the output jack, which convinced me it was some sort of wiring issue--maybe something pinched in the fairly tight enclosure. So, I rewired a few connections that looked suspect and put it back in the enclosure. After a slight hiccup with the blue LED getting bent and making me think there was another problem, I managed to get it in the enclosure and sealed up, and everything's working great! I gotta say, learning how to use the audio probe has really leveled up my troubleshooting game. It's just much easier to figure out what the issue is when you can systematically rule things out. It's the gift that keeps on giving! :)
Thanks again for sourcing the documents--that also made the job way easier!
Okay, on to the next build! (A Muffler Noise Gate.)
