SOLVED Pro-10 off board wiring
Grazza
I'm just about to build a pro-10 and noticed there is no docs, shouldnt bother me too much, I'm just not 100% sure what to do with the input output connections and which side of which 3PDT gets connected to the other if that makes sense. Can anyone direct me to another pedal build that is similar and I'll confirm the connections I was going to do with that one?
Cheers.
Thanks! I didn't look hard enough, also didn't realise the in and out are at the top of the board, should be an easy one. I'm about to build a fordoble as well and that appears to be the same.
Thanks nostradoomus
