Pro-ten green side very little gain
Jonnytexas
Blue side sounds absolutely glorious. 10/10. Green side has almost no gain. Volume and tone work as expected. I have built a few of these, so I know something is amiss. Really scratching my head. I believe all components are correct except a few I didnt have: 2n5457 instead of j201, 100pf instead of 120 above IC1, 6n8 caps instead of 8n2. Used a b100k for volume with a 100k resistor across lugs 1 and 3 to make a 50k pot. The 5k1 resistor is soldered on bottom side of board...long story. I tried using a 250k pot for the gain and it made very little difference. All 4 4148 diodes measure around .56 in circuit. Pictures and IC voltages coming shortly when I get home.
IC1....All 4.3, except pin 4--0, pin 8--8.7
Anybody have any thoughts? I got a shipment in from BLMS, so now have the proper pots in. The pedal works perfectly except for not having any appreciable gain on the green side.
Thanks szuk, it appears they are the same. I also have j112 and j113. Im fairly limited in my knowledge, but I believe it is not part of the distortion matrix, maybe a buffer?
I might try reflowing your solder joints. Very strange as the Blue side has far less gain than the Green, when working properly. Something definitely seems off. What temp is your iron set? Mine is typically around 800 F and solder flows nicely.
Thanks for the reply. My iron sits around 790. The green is producing no gain. It works like a boost pedal.
