Robusto
I’ve built the Conqueror a number of times now. Having an issue with latest version of the pcb.
I’ve done a little probing around. I’m getting signal from the transistors, but nothing from the switch poles, which leads me to suspect the transformer. I’m using 42TM013, and the layout has changed since my last build. It seems like there are pads for all three of the primary pins but only one pad for the center pin on the other side. Is this correct? Are the only connections the top three primary pins and the center pin on the bottom?
Thanks!
Thanks!
