fredk2_net13
Hello
I have problem with the PCB and the pin2 (the gate) on the Q3 I lost the soldering connection
I uploaded on my dropbox a video to show the problem
here is the link https://www.dropbox.com/s/i7yxhjnf78myuqk/20230628_215748.mp4?dl=0
As demanded on the jpg "ocelot Q3pin2" can someone show me where i have to solder the pin 2 of the Q3 on which component ?
as it's not working (like you can figure out with the dropbox video) i thought it was the Q1 Q2 Q3 ..i replace the IC6 and IC27. but i damaged and screwed a pad because i tried to remove the Q3 and i lost the connection circuit on the pin2 of the Q3
so i d like to know where the connection on the pin2 on the Q3 goes to make the "original" electric connection
if someone can test the connection with a multimeter when the pedal is off and tell me where i have to solder it exactly to make like the original pcb ...i will repair by making some a"bridge"
another question : do you think that the germanium diodes are fragile ? because i think that the pedal has got a "moderate" hit but a smack
when i mounted the first time it was working perfectly but i would like to change the jack locations on the enclosure and when i tried to replace the pcb on the enclosure, nothing worked anymore
by advance, thank you
BEST
BEST
