TL022 pin one=7.23v,pin two=7.17v,pin three=6.9v,pin four=7.42v,pin five=7.1v,pin six=6.79v,pin seven=7.1v,pin eight 0v.Have you double checked all component values? It's tedious, but going through resistor-by-resistor and cap-by-cap could lead you to something that is incorrectly placed.
Another step that could help us diagnose what's happening here: take your voltage to ground across all IC pins. They're numbered like so:
1. 8
2. 7
3. 6
4. 5
Post those measurements for all 4 ICs. That may help us pinpoint the problem
Another question: does your LFO LED light up and pulse when you plug the pedal in? If not, that's an indication that your LFO is not operational, in which case no signal will pass through your MN3207. This should light up regardless of if the pedal is "on" or "off".
This is how the 4558, TL022 pinout is. PIn 8 is power in = 9v & Pin 4 is GND!TL022 pin one=7.23v,pin two=7.17v,pin three=6.9v,pin four=7.42v,pin five=7.1v,pin six=6.79v,pin seven=7.1v,pin eight 0v.
MN3707 pin one=0v,pin two=3.4v,pin three=6.3v,pin four=6.7v,pin five=7.26v,pin six=2.5v,pin seven=0v,pin eight=3.41v
MN3102 pin one=7.2v,pin two=3.3v,pin three=6.4v,pin four=6.4v,pin five=0v,pin six=3.4v,pin seven=6.2v,pin eight=6.7v
45580 pin one=3.6v,pin two=2v,pin three=2.5v,pin four=7.2v,pin five fluctuating 0-6v,pin six=3.5v,pin seven fluctuating 2-5v,pin eight 0v……..9v depleted battery supplying 7.7v to the pcb. I don’t remember the power fluctuations the first time I checked it earlier.
